gutrov1976
Сообщение gutrov1976 »
26 май 2019, 17:37
Ничего не приложилось
[1364] [t770207744] [2019-05-26 14:33:27.716272] ***** log_redirect_to_file() succeeded *****
[1364] [t770207744] [2019-05-26 14:33:27.716542] [home_tv] [server] preparing...
[1364] [t770207744] [2019-05-26 14:33:27.716645] [home_tv] [server] reader fd: 25; writer fd: 33
[1364] [t770207744] [2019-05-26 14:33:27.717065] php engine: initializing...
[1364] [t770207744] [2019-05-26 14:33:27.806735] php engine: initialized.
[1364] [t770207744] [2019-05-26 14:33:27.806920] [home_tv] [server] resetting include path to '.:/flashdata/plugins/home_tv'...
[1364] [t770207744] [2019-05-26 14:33:27.808047] [home_tv] [server] Ok.
[1364] [t770207744] [2019-05-26 14:33:27.808316] [home_tv] [server] loading '/firmware_ext/php/bootstrap.php'...
[1364] [t770207744] [2019-05-26 14:33:27.808422] [home_tv] [server] executing "require ('/firmware_ext/php/bootstrap.php');"...
[1364] [t770207744] [2019-05-26 14:33:27.818304] [home_tv] [server] '/firmware_ext/php/bootstrap.php' loaded successfully.
[1364] [t770207744] [2019-05-26 14:33:27.818472] [home_tv] [server] loading '/firmware_ext/php/dune_api.php'...
[1364] [t770207744] [2019-05-26 14:33:27.818589] [home_tv] [server] executing "require ('/firmware_ext/php/dune_api.php');"...
[1364] [t770207744] [2019-05-26 14:33:27.849055] [home_tv] [server] '/firmware_ext/php/dune_api.php' loaded successfully.
[1364] [t770207744] [2019-05-26 14:33:27.849448] [home_tv] [server] loading '/firmware_ext/php/dune_plugin.php'...
[1364] [t770207744] [2019-05-26 14:33:27.849549] [home_tv] [server] executing "require ('/firmware_ext/php/dune_plugin.php');"...
[1364] [t770207744] [2019-05-26 14:33:27.851580] [home_tv] [server] '/firmware_ext/php/dune_plugin.php' loaded successfully.
[1364] [t770207744] [2019-05-26 14:33:27.851751] [home_tv] [server] loading '/firmware_ext/php/dune_plugin_fw.php'...
[1364] [t770207744] [2019-05-26 14:33:27.851843] [home_tv] [server] executing "require ('/firmware_ext/php/dune_plugin_fw.php');"...
[1364] [t770207744] [2019-05-26 14:33:27.855711] [home_tv] [server] '/firmware_ext/php/dune_plugin_fw.php' loaded successfully.
[1364] [t770207744] [2019-05-26 14:33:27.856000] [home_tv] [server] executing system properties cmd (number of properties: 6)...
[1364] [t770207744] [2019-05-26 14:33:27.856550] [home_tv] [server] system properties initialized successfully.
[1364] [t770207744] [2019-05-26 14:33:27.856709] [home_tv] [server] loading '/flashdata/plugins/home_tv/home_tv_plugin.php'...
[1364] [t770207744] [2019-05-26 14:33:27.856804] [home_tv] [server] executing "require ('/flashdata/plugins/home_tv/home_tv_plugin.php');"...
[1364] [t770207744] [2019-05-26 14:33:28.699880] [home_tv] [server] '/flashdata/plugins/home_tv/home_tv_plugin.php' loaded successfully.
[1364] [t770207744] [2019-05-26 14:33:28.700061] [home_tv] [server] ready.
[1364] [t770207744] [2019-05-26 14:33:28.700144] [home_tv] [server] main loop started.
[1364] [t770207744] [2019-05-26 14:33:28.702872] Instantiating plugin...
[1364] [t770207744] [2019-05-26 14:33:28.855727] Plugin instance created.
[1364] [t770207744] [2019-05-26 14:33:28.856481] <...
[1364] [t770207744] [2019-05-26 14:33:28.856799] handler_id => main_handler
[1364] [t770207744] [2019-05-26 14:33:28.856998] control_id => hard_reset
[1364] [t770207744] [2019-05-26 14:33:28.857264] play_mode => none
[1364] [t770207744] [2019-05-26 14:33:28.857476] selected_media_url => run
[1364] [t770207744] [2019-05-26 14:33:28.857642] ...>
[1364] [t770207744] [2019-05-26 14:33:28.857896] Do reboot stb...
[1364] [t770207744] [2019-05-26 14:33:29.391391] BlockingReader (25): read() returned EOF.
[1364] [t770207744] [2019-05-26 14:33:29.391605] [home_tv] [server] error: read failed.
[1364] [t770207744] [2019-05-26 14:33:29.391698] [home_tv] [server] main loop finished.
[1364] [t770207744] [2019-05-26 14:33:29.391782] php engine: finalizing...
[1364] [t770207744] [2019-05-26 14:33:29.462712] php engine: finalized.
[1364] [t770207744] [2019-05-26 14:33:29.462883] [home_tv] [server] syncing disks...
[1364] [t770207744] [2019-05-26 14:33:29.469356] [home_tv] [server] finalized.
[1364] [t770207744] [2019-05-26 14:33:29.469916] [home_tv] [server] exiting (code: 0)...
(!!!) *** WARNING [Application exited without deinitialization of DirectFB!] *** [src/core/core.c:859 in dfb_core_deinit_check()]
(!) FUSION_KILL --> Bad file descriptor
gutrov1976 писал(а): ↑
26 май 2019, 19:26
Не стоит эти портянки постить, файл приаттачьте (в первый раз файл не приаттачился из-за ограничений прав на форуме, теперь после первого одобренного поста будет аттачиться). В крайнем случае под спойлер прячьте.
В вашем логе пусто. Еще раз запустите любой канал, потом стоп, присоедините файл лога к сообщению.
parter28
Сообщение parter28 »
Установил плагин на Duna HD 102, каналы переключаются, а изображения и звука нет. В чем причина?
parter28 писал(а): ↑
03 июн 2019, 16:18
Выключите воспроизведение удп стримов в опциях плагина.
PolSmit
Сообщение PolSmit »
Здравствуйте. После перехода с Dune HD Solo 4K (Сигма) на Dune HD Pro 4K (Realtek - Android) обнаружил что после запуска плагина не запоминается и не открывается последний просмотренный канал. Всегда запускается тот канал, который стоит первым в списке Избранных.
На Solo 4K запоминалось :) Это условно нормально или у меня что-то не то?
Версия плагина 2.9.1 (последняя?), прошивка в Pro 4K - последняя бета - 190601_0246_r13.
PolSmit писал(а): ↑
09 июн 2019, 08:51
Скорей всего дело в прошивке, что-то опять поломали. У меня нет прошки, не могу проверить и точно сказать.
lorusqus
Сообщение lorusqus »
Уважаемый автор, добрый день!
Ещё раз благодарю Вас за невероятно удобный и качественный плагин. У меня Dune 301, плагин всегда работает на высшем уровне! Спасибо!!!
Вопрос в следующем: приобрёл телевизор в деревню TELEFUNKEN TF-LED40S43T2S с Android ОС 4.4.4. Нужен такой же простой и качественный плагин для просмотра ТВ через интернет без участия Dune соответственно) Есть ли в вашем каталоге проектов, плагин для Android OS 4.4.4? Или может посоветуете решение, напрмер одного из ваших партнёров, кто помогает создавать "Домашнее ТВ"?
Заранее спасибо за ответ. Код проверки: 133р на пиво)
Dune HD TV-301
lorusqus писал(а): ↑
13 июн 2019, 08:58
Спасибо за поддержку. К сожалению (а может и к счастью) без дюны вам не обойтись. Версия андройда на вашем ТВ слишком древняя, вряд ли вы вообще что-то найдете под него. Я лично под андройд не пишу, не умею.
lnp3
Сообщение lnp3 »
Во-первых, плагин просто сказка. Желать больше нечего. Автору низкий поклон и уважение.
Во-вторых, появился баг. Последнее обновление принесло неожиданное: если долго листать каналы, начинает сильно тормозить интерфейс. Даже в дюновском интерфейсе после этого всё едва работает - с иконки на иконку выделение перемещается за 2-3 секунды. Но стоит перезагрузить аппарат, как всё восстанавливается. Думал, что проблема аппаратная, но тестирование на SKY и Neo 4K T2+ даёт одинаковые результаты. Если не пользоваться плагином, аппарат работает отлично. Стоит начать активно перелистывать каналы, и через час-другой всё начинает едва шевелиться. В старой версии плагина такого не было.
Что можно сделать? Спасибо!
Не замечал. Видео можете сделать? Через час-другой говорите? И этот час другой надо сидеть и переключать каналы?
lnp3
Сообщение lnp3 »
Это пенсионер сидит и переключает каналы, читает описания - ищет интересное для себя. Видео сделать? Весь процесс заснять затруднительно, а видео тормозов есть ли смысл? Вы уж поверьте на слово - тормоза такие, что я с большим трудом добираюсь до кнопки "перезагрузка". Такое ощущение, что накапливается что-то во время этих переключений каналов. Кстати, помогает не только перезагрузка из меню, но просто выключение питания.
Я бы и не подумал на плагин, но стал проверять на другом аппарате (Neo 4K T2+) с такой же прошивкой и версией плагина и добился того же результата. Просто выбрал общий список каналов и стал листать от первого до последнего и обратно. Кажется, хватило часа.
Вы уж извините, но, похоже, что-то в последней версии плагина.
excepte
Сообщение excepte »
14 июн 2019, 00:14
А куда Dune EPG грузит? Уж не в RAM ли?
lnp3
Сообщение lnp3 »
excepte писал(а): ↑
14 июн 2019, 09:50
Да, кстати, может быть, эти данные кэшируются? Их в последней версии плагина не стало больше, чтобы вызвать переполнение?
lnp3 писал(а): ↑
14 июн 2019, 09:38
Поставьте ему фритв, пусть пощелкает.
Листать - это переключать на канал или просто программу смотреть? Если только программу, то попадались ли каналы без программы (не загрузилась например)?
excepte писал(а): ↑
14 июн 2019, 09:50
Естественно в рам, куда же еще?! Но места в раме новых дюн хватает с лихвой. Здесь не может быть проблем.
lnp3
Сообщение lnp3 »
14 июн 2019, 10:01
Хотелось бы всё же пенсионера оставить на этом плагине - привычка для старых людей очень важна.
Листание происходит так: он нажимает на среднюю кнопку, получает программу на экране, начинает нажимать кнопки вверх и вниз, читает описания, иногда нажимает кнопку вправо, чтобы почитать полное описание. Бывало такое, что на каких-то каналах не загружалась программа. Я это тоже замечал. При этом, если перейти на другой канал, а потом обратно, то программа как правило появляется. Все манипуляции производятся при каком-то уже работающем канале.
У меня эффект тормозов проявляется быстрее, потому что я листаю быстро, не читая описания. Пенсионер же может за целый день не поймать этого, если не занимается долгими поисками чего-то интересного.
lnp3 писал(а): ↑
14 июн 2019, 10:10
Если не хотите помочь, тогда не жалуйтесь. Что случится с пенсионером если он поюзает недельку другой аналогичный плагин? Правильно, ничего не случится, переживет. А мне это может помочь.
Я конечно попробую полистать по вашей методике. Но до сих пор тормозов не наблюдал.
lnp3
Сообщение lnp3 »
Если это поможет, конечно переключу на другой плагин. Но как это поможет? И что мне при этом нужно сделать ещё? Какие-то логи или другое?
lnp3 писал(а): ↑
14 июн 2019, 10:37
Мы выясним: такое происходит только в Домашнем или нет. Логи не нужны.
У меня есть подозрения с чем это связано, но нет сиюминутных решений, поэтому нужно проверить. А потом думать.
lnp3
Сообщение lnp3 »
14 июн 2019, 11:04
Поставил FreeTV, обучил пенсионера, через неделю доложу о результатах.
