Никак, у всех плашка кривая.
У сигм чуть поточнее.
К сожалению нет ни то, ни другого. Раньше всё было.
Neo 4k T2 Plus
200914_1539_r13
Real Vision 4K
последняя версия прошивки
200914_1539_r13
Real Vision 4K
Что-то у меня плагин дурит, случайно нажал Info, потом Return, плеер Dou 4k пишет Error и вываливается из плагина, это нормально? Лог прилепил.
[11950] [t2992361472] [2020-08-23 14:57:36.588830] ***** log_redirect_to_file() succeeded *****
[11950] [t2992361472] [2020-08-23 14:57:36.591191] [home_tv] [server] preparing...
[11950] [t2992361472] [2020-08-23 14:57:36.592447] [home_tv] [server] reader fd: 46; writer fd: 49
[11950] [t2992361472] [2020-08-23 14:57:36.593966] php engine: initializing...
[11950] [t2992361472] [2020-08-23 14:57:36.640417] php engine: initialized.
[11950] [t2992361472] [2020-08-23 14:57:36.642274] [home_tv] [server] resetting include path to '.:/persistfs/plugins/home_tv'...
[11950] [t2992361472] [2020-08-23 14:57:36.645962] [home_tv] [server] Ok.
[11950] [t2992361472] [2020-08-23 14:57:36.647566] [home_tv] [server] loading '/firmware_ext/php/bootstrap.php'...
[11950] [t2992361472] [2020-08-23 14:57:36.649740] [home_tv] [server] executing "require ('/firmware_ext/php/bootstrap.php');"...
[11950] [t2992361472] [2020-08-23 14:57:36.657645] [home_tv] [server] '/firmware_ext/php/bootstrap.php' loaded successfully.
[11950] [t2992361472] [2020-08-23 14:57:36.659533] [home_tv] [server] loading '/firmware_ext/php/dune_api.php'...
[11950] [t2992361472] [2020-08-23 14:57:36.661052] [home_tv] [server] executing "require ('/firmware_ext/php/dune_api.php');"...
[11950] [t2992361472] [2020-08-23 14:57:36.673630] [home_tv] [server] '/firmware_ext/php/dune_api.php' loaded successfully.
[11950] [t2992361472] [2020-08-23 14:57:36.675801] [home_tv] [server] loading '/firmware_ext/php/dune_plugin.php'...
[11950] [t2992361472] [2020-08-23 14:57:36.677267] [home_tv] [server] executing "require ('/firmware_ext/php/dune_plugin.php');"...
[11950] [t2992361472] [2020-08-23 14:57:36.679612] [home_tv] [server] '/firmware_ext/php/dune_plugin.php' loaded successfully.
[11950] [t2992361472] [2020-08-23 14:57:36.681590] [home_tv] [server] loading '/firmware_ext/php/dune_plugin_fw.php'...
[11950] [t2992361472] [2020-08-23 14:57:36.682956] [home_tv] [server] executing "require ('/firmware_ext/php/dune_plugin_fw.php');"...
[11950] [t2992361472] [2020-08-23 14:57:36.685728] [home_tv] [server] '/firmware_ext/php/dune_plugin_fw.php' loaded successfully.
[11950] [t2992361472] [2020-08-23 14:57:36.687805] [home_tv] [server] executing system properties cmd (number of properties: 6)...
[11950] [t2992361472] [2020-08-23 14:57:36.689466] [home_tv] [server] system properties initialized successfully.
[11950] [t2992361472] [2020-08-23 14:57:36.690642] [home_tv] [server] loading '/persistfs/plugins/home_tv/home_tv_plugin.php'...
[11950] [t2992361472] [2020-08-23 14:57:36.691360] [home_tv] [server] executing "require ('/persistfs/plugins/home_tv/home_tv_plugin.php');"...
[11950] [t2992361472] [2020-08-23 14:57:36.937070] [home_tv] [server] '/persistfs/plugins/home_tv/home_tv_plugin.php' loaded successfully.
[11950] [t2992361472] [2020-08-23 14:57:36.939476] [home_tv] [server] ready.
[11950] [t2992361472] [2020-08-23 14:57:36.941025] [home_tv] [server] main loop started.
[11950] [t2992361472] [2020-08-23 14:57:36.944232] Instantiating plugin...
[11950] [t2992361472] [2020-08-23 14:57:37.182520] Plugin instance created.
[11950] [t2992361472] [2020-08-23 14:57:37.185391] <...
[11950] [t2992361472] [2020-08-23 14:57:37.187408] handler_id => main_handler
[11950] [t2992361472] [2020-08-23 14:57:37.189124] control_id => plugin_entry
[11950] [t2992361472] [2020-08-23 14:57:37.191142] action_id => launch
[11950] [t2992361472] [2020-08-23 14:57:37.192588] mandratory_playback => 0
[11950] [t2992361472] [2020-08-23 14:57:37.194628] play_mode => none
[11950] [t2992361472] [2020-08-23 14:57:37.195346] selected_media_url => run
[11950] [t2992361472] [2020-08-23 14:57:37.196083] ...>
[11950] [t2992361472] [2020-08-23 14:57:37.202153] DunePalettePatcher initialized successfully!
[11950] [t2992361472] [2020-08-23 14:57:37.203821] Set macro_location to "ural", location to "67662621"
[11950] [t2992361472] [2020-08-23 14:57:37.204735] Start loading metadata...
[11950] [t2992361472] [2020-08-23 14:57:37.206906] Loading from the local cache "1597831863"
[11950] [t2992361472] [2020-08-23 14:57:37.210887] Apply location to "1000184", sub_location to "67662621"
[11950] [t2992361472] [2020-08-23 14:57:37.212592]
[11950] [t2992361472] [2020-08-23 14:57:37.214049] *** Plugin settings dump ***
[11950] [t2992361472] [2020-08-23 14:57:37.214974] app_version = 3.0b6 (06.08.2020)
[11950] [t2992361472] [2020-08-23 14:57:37.215721] repeater_ver_idx = 14
[11950] [t2992361472] [2020-08-23 14:57:37.216442] autoplay_enable = off
[11950] [t2992361472] [2020-08-23 14:57:37.217177] auto_resume_enable = off
[11950] [t2992361472] [2020-08-23 14:57:37.217882] favorites_enable = on
[11950] [t2992361472] [2020-08-23 14:57:37.218600] location_id = mrf-ural-1000184-67662621
[11950] [t2992361472] [2020-08-23 14:57:37.219413] location_name = Урал::г. Тобольск (Тюменская область)
[11950] [t2992361472] [2020-08-23 14:57:37.220289] time_zone_offset = -18000
[11950] [t2992361472] [2020-08-23 14:57:37.221025] sdp_root_url =
[11950] [t2992361472] [2020-08-23 14:57:37.221738] autoscan_delay = 0
[11950] [t2992361472] [2020-08-23 14:57:37.222442] epg_enable = on
[11950] [t2992361472] [2020-08-23 14:57:37.223136] ext_epg_enable = on
[11950] [t2992361472] [2020-08-23 14:57:37.223827] epg_font_size = small
[11950] [t2992361472] [2020-08-23 14:57:37.224537] epg_fill_enable = on
[11950] [t2992361472] [2020-08-23 14:57:37.225696] epg_cache_enable = on
[11950] [t2992361472] [2020-08-23 14:57:37.226892] quality_filter = highest
[11950] [t2992361472] [2020-08-23 14:57:37.227729] http_secury = on
[11950] [t2992361472] [2020-08-23 14:57:37.228655] hls_bitrate_prefer = vbr
[11950] [t2992361472] [2020-08-23 14:57:37.230411] hls_buff_size_ms = 5000
[11950] [t2992361472] [2020-08-23 14:57:37.231177] playback_udp_enabled = off
[11950] [t2992361472] [2020-08-23 14:57:37.231899] playback_dvb_enabled = off
[11950] [t2992361472] [2020-08-23 14:57:37.232682] udpxy_enable = off
[11950] [t2992361472] [2020-08-23 14:57:37.233460] udpxy_ip_port = 192.168.1.1:4022
[11950] [t2992361472] [2020-08-23 14:57:37.234700] udpxy_buff_size_ms = 1000
[11950] [t2992361472] [2020-08-23 14:57:37.236194] tv_archives_enabled = on
[11950] [t2992361472] [2020-08-23 14:57:37.237345] tv_archives_playback_stream_type = auto
[11950] [t2992361472] [2020-08-23 14:57:37.238285] tv_archives_reload_when_resume = on
[11950] [t2992361472] [2020-08-23 14:57:37.239281] export_m3u_enable = off
[11950] [t2992361472] [2020-08-23 14:57:37.240306] export_m3u_path_to_playlist = usb0:/home_tv_playlist.m3u
[11950] [t2992361472] [2020-08-23 14:57:37.241320] parental_enable = off
[11950] [t2992361472] [2020-08-23 14:57:37.242397] parental_pin =
[11950] [t2992361472] [2020-08-23 14:57:37.243423] custom_repeat_key = key_clear
[11950] [t2992361472] [2020-08-23 14:57:37.244338] custom_epg_key = key_info
[11950] [t2992361472] [2020-08-23 14:57:37.245196] custom_clock_key = key_clear
[11950] [t2992361472] [2020-08-23 14:57:37.246055] custom_clock_pos = 1550,80
[11950] [t2992361472] [2020-08-23 14:57:37.246937] check_skin_palette = on
[11950] [t2992361472] [2020-08-23 14:57:37.247807] groups_catalog = default
[11950] [t2992361472] [2020-08-23 14:57:37.248762] grouping_similars_channels = on
[11950] [t2992361472] [2020-08-23 14:57:37.249744] *** *** *** *** *** *** ***
[11950] [t2992361472] [2020-08-23 14:57:37.250929] *** Dune product info ***
[11950] [t2992361472] [2020-08-23 14:57:37.306224] product_id = duo4k
[11950] [t2992361472] [2020-08-23 14:57:37.307816] platform_kind = 8758
[11950] [t2992361472] [2020-08-23 14:57:37.309040] firmware_ver = 190919_0242_r11
[11950] [t2992361472] [2020-08-23 14:57:37.376083] ip_address = 192.168.1.12
[11950] [t2992361472] [2020-08-23 14:57:37.377568] *** *** *** *** *** *** ***
[11950] [t2992361472] [2020-08-23 14:57:37.449617] <...
[11950] [t2992361472] [2020-08-23 14:57:37.451228] handler_id => main_handler
[11950] [t2992361472] [2020-08-23 14:57:37.452396] control_id => launch
[11950] [t2992361472] [2020-08-23 14:57:37.453292] dialog_frame_style => glass
[11950] [t2992361472] [2020-08-23 14:57:37.454151] mandratory_playback => 0
[11950] [t2992361472] [2020-08-23 14:57:37.455002] play_mode => none
[11950] [t2992361472] [2020-08-23 14:57:37.456140] parent_media_url => {"screen_id":"splash_screen"}
[11950] [t2992361472] [2020-08-23 14:57:37.457035] selected_media_url => {"screen_id":"splash_screen"}
[11950] [t2992361472] [2020-08-23 14:57:37.457905] ...>
[11950] [t2992361472] [2020-08-23 14:57:37.500793] <...
[11950] [t2992361472] [2020-08-23 14:57:37.502214] handler_id => home_tv_handler
[11950] [t2992361472] [2020-08-23 14:57:37.503289] control_id => start_plugin
[11950] [t2992361472] [2020-08-23 14:57:37.504182] dialog_frame_style => glass
[11950] [t2992361472] [2020-08-23 14:57:37.505161] mandratory_playback => 0
[11950] [t2992361472] [2020-08-23 14:57:37.506235] play_mode => none
[11950] [t2992361472] [2020-08-23 14:57:37.507149] parent_media_url => {"screen_id":"splash_screen"}
[11950] [t2992361472] [2020-08-23 14:57:37.508021] selected_media_url => {"screen_id":"splash_screen"}
[11950] [t2992361472] [2020-08-23 14:57:37.509083] ...>
[11950] [t2992361472] [2020-08-23 14:57:37.551931] <...
[11950] [t2992361472] [2020-08-23 14:57:37.553341] handler_id => home_tv_handler
[11950] [t2992361472] [2020-08-23 14:57:37.554455] control_id => start_plugin
[11950] [t2992361472] [2020-08-23 14:57:37.555364] dialog_frame_style => glass
[11950] [t2992361472] [2020-08-23 14:57:37.556262] mandratory_playback => 0
[11950] [t2992361472] [2020-08-23 14:57:37.557396] play_mode => none
[11950] [t2992361472] [2020-08-23 14:57:37.558309] parent_media_url => {"screen_id":"splash_screen"}
[11950] [t2992361472] [2020-08-23 14:57:37.559247] selected_media_url => {"screen_id":"splash_screen"}
[11950] [t2992361472] [2020-08-23 14:57:37.560373] ...>
[11950] [t2992361472] [2020-08-23 14:57:37.608287] Set SDP network address to "auto"
[11950] [t2992361472] [2020-08-23 14:57:37.609893] Set macro_location to "ural", location to "67662621"
[11950] [t2992361472] [2020-08-23 14:57:37.611216] Start loading metadata...
[11950] [t2992361472] [2020-08-23 14:57:37.612606] Loading from the local cache "1597831863"
[11950] [t2992361472] [2020-08-23 14:57:37.617231] Apply location to "1000184", sub_location to "67662621"
[11950] [t2992361472] [2020-08-23 14:57:37.635709] Playlist of tv channels found in cache: "1597832149"
[11950] [t2992361472] [2020-08-23 14:57:37.638397] Generation date of playlist "2020-08-19 10:15:49"
[11950] [t2992361472] [2020-08-23 14:57:37.663113] Playlist "1597832149" loaded
[11950] [t2992361472] [2020-08-23 14:57:37.665190] Loading tv channels from playlist...
[11950] [t2992361472] [2020-08-23 14:57:37.763723] Tv channels loaded successfull!
[11950] [t2992361472] [2020-08-23 14:57:37.766512] Loaded at 0.15836405754089 secs
[11950] [t2992361472] [2020-08-23 14:57:37.771455] Playlist of radio stations found in cache: "1597832149"
[11950] [t2992361472] [2020-08-23 14:57:37.773803] Playlist "1597832149" loaded
[11950] [t2992361472] [2020-08-23 14:57:37.775882] Loading radio stations from playlist...
[11950] [t2992361472] [2020-08-23 14:57:37.779508] Radio stations loaded successfull!
[11950] [t2992361472] [2020-08-23 14:57:42.383744] <...
[11950] [t2992361472] [2020-08-23 14:57:42.388501] handler_id => tv_channels
[11950] [t2992361472] [2020-08-23 14:57:42.391547] control_id => tv_play
[11950] [t2992361472] [2020-08-23 14:57:42.393662] play_mode => none
[11950] [t2992361472] [2020-08-23 14:57:42.395837] parent_media_url => {"screen_id":"tv_channels","group_id":"__home_tv_group_hdtv_channels"}
[11950] [t2992361472] [2020-08-23 14:57:42.397950] selected_media_url => {"group_id":"__home_tv_group_hdtv_channels","channel_id":"2c115974cbf39617193c9ca3a0417690"}
[11950] [t2992361472] [2020-08-23 14:57:42.400174] sel_ndx => 0
[11950] [t2992361472] [2020-08-23 14:57:42.402362] ...>
[11950] [t2992361472] [2020-08-23 14:57:42.434526] <...
[11950] [t2992361472] [2020-08-23 14:57:42.435803] handler_id => home_tv_handler
[11950] [t2992361472] [2020-08-23 14:57:42.436726] control_id => tv_play
[11950] [t2992361472] [2020-08-23 14:57:42.437490] initial_media_url => {"group_id":"__home_tv_group_hdtv_channels","channel_id":"2c115974cbf39617193c9ca3a0417690"}
[11950] [t2992361472] [2020-08-23 14:57:42.438590] play_mode => none
[11950] [t2992361472] [2020-08-23 14:57:42.439409] parent_media_url => {"screen_id":"tv_channels","group_id":"__home_tv_group_hdtv_channels"}
[11950] [t2992361472] [2020-08-23 14:57:42.440691] selected_media_url => {"group_id":"__home_tv_group_hdtv_channels","channel_id":"2c115974cbf39617193c9ca3a0417690"}
[11950] [t2992361472] [2020-08-23 14:57:42.442283] sel_ndx => 0
[11950] [t2992361472] [2020-08-23 14:57:42.443889] ...>
[11950] [t2992361472] [2020-08-23 14:57:42.542286] EPG disk cache initialized in "/tmp/plugins/home_tv/cache/epg"
[11950] [t2992361472] [2020-08-23 14:57:42.897887] Channels loaded at 0.35744786262512 secs
[11950] [t2992361472] [2020-08-23 14:57:43.629645] HTTP fetching 'https://zabava-htlive.cdn.ngenix.net/hl ... riant.m3u8'...
[11950] [t2992361472] [2020-08-23 14:57:44.002322] HTTP OK (200)
[11950] [t2992361472] [2020-08-23 14:57:44.005728] Change playback URL to "https://a775798172-zabava-htlive.cdn.ng ... 1598191200"
[11950] [t2992361472] [2020-08-23 14:57:44.019082] Load tv program from disk cache "4abb78b0e114e3882c77a3f2d782b908_1598140800_1598486400"
[11950] [t2992361472] [2020-08-23 14:57:44.024815] Load tv program from disk cache "4abb78b0e114e3882c77a3f2d782b908_1598227200_1598486400"
[11950] [t2992361472] [2020-08-23 14:57:46.239565] <...
[11950] [t2992361472] [2020-08-23 14:57:46.242897] handler_id => home_tv_handler
[11950] [t2992361472] [2020-08-23 14:57:46.244358] control_id => do_cache_osd_images
[11950] [t2992361472] [2020-08-23 14:57:46.246967] playback_position => 0
[11950] [t2992361472] [2020-08-23 14:57:46.247819] playback_mode => plugin_tv
[11950] [t2992361472] [2020-08-23 14:57:46.250844] plugin_tv_channel_id => 2c115974cbf39617193c9ca3a0417690
[11950] [t2992361472] [2020-08-23 14:57:46.253545] playback_browser_activated => 0
[11950] [t2992361472] [2020-08-23 14:57:46.257423] ...>
[11950] [t2992361472] [2020-08-23 14:57:46.926199] <...
[11950] [t2992361472] [2020-08-23 14:57:46.928908] handler_id => home_tv_handler
[11950] [t2992361472] [2020-08-23 14:57:46.931937] control_id => do_cache_osd_images
[11950] [t2992361472] [2020-08-23 14:57:46.936097] playback_position => 0
[11950] [t2992361472] [2020-08-23 14:57:46.941238] playback_mode => plugin_tv
[11950] [t2992361472] [2020-08-23 14:57:46.944581] plugin_tv_channel_id => 2c115974cbf39617193c9ca3a0417690
[11950] [t2992361472] [2020-08-23 14:57:46.948674] playback_browser_activated => 0
[11950] [t2992361472] [2020-08-23 14:57:46.956230] ...>
[11950] [t2992361472] [2020-08-23 14:57:47.599832] <...
[11950] [t2992361472] [2020-08-23 14:57:47.605791] handler_id => home_tv_handler
[11950] [t2992361472] [2020-08-23 14:57:47.609792] control_id => do_cache_osd_images
[11950] [t2992361472] [2020-08-23 14:57:47.611049] playback_position => 1
[11950] [t2992361472] [2020-08-23 14:57:47.612412] playback_mode => plugin_tv
[11950] [t2992361472] [2020-08-23 14:57:47.613656] plugin_tv_channel_id => 2c115974cbf39617193c9ca3a0417690
[11950] [t2992361472] [2020-08-23 14:57:47.614838] playback_browser_activated => 0
[11950] [t2992361472] [2020-08-23 14:57:47.615594] ...>
[11950] [t2992361472] [2020-08-23 14:57:48.327663] <...
[11950] [t2992361472] [2020-08-23 14:57:48.330540] handler_id => home_tv_handler
[11950] [t2992361472] [2020-08-23 14:57:48.331682] control_id => do_cache_osd_images
[11950] [t2992361472] [2020-08-23 14:57:48.332613] playback_position => 2
[11950] [t2992361472] [2020-08-23 14:57:48.333511] playback_mode => plugin_tv
[11950] [t2992361472] [2020-08-23 14:57:48.334403] plugin_tv_channel_id => 2c115974cbf39617193c9ca3a0417690
[11950] [t2992361472] [2020-08-23 14:57:48.335298] playback_browser_activated => 0
[11950] [t2992361472] [2020-08-23 14:57:48.336646] ...>
[11950] [t2992361472] [2020-08-23 14:57:48.938573] <...
[11950] [t2992361472] [2020-08-23 14:57:48.940209] handler_id => home_tv_handler
[11950] [t2992361472] [2020-08-23 14:57:48.942167] control_id => do_cache_osd_images
[11950] [t2992361472] [2020-08-23 14:57:48.943250] playback_position => 2
[11950] [t2992361472] [2020-08-23 14:57:48.944172] playback_mode => plugin_tv
[11950] [t2992361472] [2020-08-23 14:57:48.945046] plugin_tv_channel_id => 2c115974cbf39617193c9ca3a0417690
[11950] [t2992361472] [2020-08-23 14:57:48.945908] playback_browser_activated => 0
[11950] [t2992361472] [2020-08-23 14:57:48.946814] ...>
[11950] [t2992361472] [2020-08-23 14:57:49.549609] <...
[11950] [t2992361472] [2020-08-23 14:57:49.556901] handler_id => home_tv_handler
[11950] [t2992361472] [2020-08-23 14:57:49.561146] control_id => do_cache_osd_images
[11950] [t2992361472] [2020-08-23 14:57:49.564849] playback_position => 3
[11950] [t2992361472] [2020-08-23 14:57:49.568960] playback_mode => plugin_tv
[11950] [t2992361472] [2020-08-23 14:57:49.572757] plugin_tv_channel_id => 2c115974cbf39617193c9ca3a0417690
[11950] [t2992361472] [2020-08-23 14:57:49.576040] playback_browser_activated => 0
[11950] [t2992361472] [2020-08-23 14:57:49.579964] ...>
[11950] [t2992361472] [2020-08-23 14:57:52.010815] <...
[11950] [t2992361472] [2020-08-23 14:57:52.014618] handler_id => home_tv_handler
[11950] [t2992361472] [2020-08-23 14:57:52.017678] control_id => show_custom_epg
[11950] [t2992361472] [2020-08-23 14:57:52.021433] playback_mode => plugin_tv
[11950] [t2992361472] [2020-08-23 14:57:52.023881] plugin_tv_channel_id => 2c115974cbf39617193c9ca3a0417690
[11950] [t2992361472] [2020-08-23 14:57:52.026511] playback_browser_activated => 0
[11950] [t2992361472] [2020-08-23 14:57:52.028919] ...>
[11950] [t2992361472] [2020-08-23 14:57:52.073466] <...
[11950] [t2992361472] [2020-08-23 14:57:52.076395] handler_id => epg_screen_handler
[11950] [t2992361472] [2020-08-23 14:57:52.079027] control_id => show
[11950] [t2992361472] [2020-08-23 14:57:52.083306] selected_media_url => {"screen_id":"program_info","group_id":"__home_tv_group_all_channels","channel_id":"2c115974cbf39617193c9ca3a0417690"}
[11950] [t2992361472] [2020-08-23 14:57:52.086981] playback_mode => plugin_tv
[11950] [t2992361472] [2020-08-23 14:57:52.090517] plugin_tv_channel_id => 2c115974cbf39617193c9ca3a0417690
[11950] [t2992361472] [2020-08-23 14:57:52.095692] playback_browser_activated => 0
[11950] [t2992361472] [2020-08-23 14:57:52.099300] ...>
[11950] [t2992361472] [2020-08-23 14:57:55.264250] <...
[11950] [t2992361472] [2020-08-23 14:57:55.268915] handler_id => epg_screen_handler
[11950] [t2992361472] [2020-08-23 14:57:55.273217] control_id => on_choose_return_button
[11950] [t2992361472] [2020-08-23 14:57:55.277096] play_mode => plugin_tv
[11950] [t2992361472] [2020-08-23 14:57:55.280481] parent_media_url => {"screen_id":"program_info","group_id":"__home_tv_group_all_channels","channel_id":"2c115974cbf39617193c9ca3a0417690","day_start_tm_utc":0,"start_tm_utc":1598192400}
[11950] [t2992361472] [2020-08-23 14:57:55.281916] selected_media_url => {"screen_id":"program_info","group_id":"__home_tv_group_all_channels","channel_id":"2c115974cbf39617193c9ca3a0417690","day_start_tm_utc":0,"start_tm_utc":1598192400}
[11950] [t2992361472] [2020-08-23 14:57:55.282936] ...>
[11950] [t2992361472] [2020-08-23 14:57:57.374361] <...
[11950] [t2992361472] [2020-08-23 14:57:57.377982] handler_id => epg_screen_handler
[11950] [t2992361472] [2020-08-23 14:57:57.381597] control_id => on_choose_return_button
[11950] [t2992361472] [2020-08-23 14:57:57.383908] play_mode => plugin_tv
[11950] [t2992361472] [2020-08-23 14:57:57.386180] parent_media_url => {"screen_id":"programs_list","group_id":"__home_tv_group_all_channels","channel_id":"2c115974cbf39617193c9ca3a0417690","day_start_tm_utc":1598140800}
[11950] [t2992361472] [2020-08-23 14:57:57.388406] selected_media_url => {"screen_id":"programs_list","group_id":"__home_tv_group_all_channels","channel_id":"2c115974cbf39617193c9ca3a0417690","day_start_tm_utc":1598140800,"start_tm_utc":1598192400}
[11950] [t2992361472] [2020-08-23 14:57:57.391597] sel_ndx => 19
[11950] [t2992361472] [2020-08-23 14:57:57.394414] ...>
Действительно, у смартлаба тут некоторые изменения. Поправлю в следующем апдейте.
Ненормально, но в логах все чисто. Видимо шелл глубоко внутри себя что-то отторгнул.
Спасибо, дождёмся, обновимся. Плагин очень хороший.
Neo 4k T2 Plus
200914_1539_r13
Real Vision 4K
200914_1539_r13
Real Vision 4K
К сожалению не обладаю дюной на последней сигме чтобы самому с этим экспериментировать
- nonstop1977
Здравствуйте , подскажите пожалуйста, что может быть, после обновления на последнею версию у Dune HD 303D прошивка b9 появляется вот это: Фатальная ошибка! Плагин сообщает " EPG : EPG Service not registered ! Пожалуйста перезагрузите медиаплеер и повторите попытку. Если проблема повторится вновь, сообщите разработчику. После перезагрузки , тоже самое.
Потому что у вас прописаны EPG ID на некоторых каналах, которые теперь изменились с целью упорядочивания в единообразие. Самое простое - это очистить кеш (Настройки плагина -> Сброс настроек -> Только очистить кеш память -> Применить) и пересканировать каналы. Ну или вручную лезть в каждый канал и исправлять или удалять. Удалить плагин и установить заново тоже поможет.nonstop1977 писал(а): ↑23 авг 2020, 23:11Здравствуйте , подскажите пожалуйста, что может быть, после обновления на последнею версию у Dune HD 303D прошивка b9 появляется вот это: Фатальная ошибка! Плагин сообщает " EPG : EPG Service not registered ! Пожалуйста перезагрузите медиаплеер и повторите попытку. Если проблема повторится вновь, сообщите разработчику. После перезагрузки , тоже самое.
- nonstop1977
Спасибо , очистка кеша помогла.
- Stepan Razin
Полный сброс приложения с очисткой кэша вернул работоспособность плагина.
Но программа телепередач подтормаживает жутко - при попытке пролистать вверх думает от 5 до 10 секунд.
Что-то они там поменяли походу.
Но главное, что заработало снова.
Dune Realbox 4K
Dune SmartBox 4K
Dune SmartBox 4K
У кого тормозит программа, попробуйте отключить расширенный епг. Лучше?
Не понял разницы: ни в скорости работы приложения, ни в измениии епг. Нажимаю при упрощенном на на описание фильма и кажет все тоже, что, и на расширенном...
PS От плагина сильно радуюсь) Спасибо, плеер теперь "при деле".
DUNE HD TV-303D(190919_0242_r11), сис. SD, HDD
DUNE HD Magic 4K Plus (240123_027_r22)
РТ 100Mbps
РТ 100Mbps
поддерживаю! Не понял, что изменилось)
Smartbox 4K (230606_0206_r21)
Real Vision 4K Plus (240123_0207_r22)
Как так, не заметили?!
По умолчанию (после установки) расширенный телегид включен:
И вот как он выглядит во время просмотра (правая панель с картинкой):
А если его отключить:
То панель с картинкой не отображается:
Т.о. не скачиваются эти самые картинки! Вот и хотелось сравнить, без них быстрей чем с ними, или нет разницы?
ЗЫ: На Северо-Западе сейчас сервер жестко тупит, часто не отдает программу.
Что "Расширенный", что "Не расширенный", на скорость работы плагина у меня не влияет.Brigadir писал(а): ↑25 авг 2020, 20:02Как так, не заметили?!
РТ 100Mbps
РТ 100Mbps
теперь понятно, что есть расширенный)) я туда даже и не заглядывал никогда)
потыкался сейчас - при перемещении по каналам особой разницы не увидел, может доли секунды, но, допускаю, что это просто осознание того, что расширенный EPG отключен))
загрузка происходит как раз тогда, когда заходишь на передачу и подгружается эта картинка
- Алекс00099988877
Подскажите появилась в пользовании ещё одна dune 102 архивы работают в норме без нареканий, а вот прямой эфир при переключении просто чёрный экран, программа и что идёт отображается, настройки сравнил с первой, вроде бы ничего не отличается кроме как модель dune 102v2 где покопать
Dune smart Box 4k plus
Dune 102w
Dune 102v2
Dune 102w
Dune 102v2
